Poor Wifi at home
Linzi94
For a long time now my wifi at home has been poor. Quite often it’s ok for the first minute of using social media or online shopping then it won’t work and I have to switch device to 4G. Doesn’t matter the time of day. This is with iPhone 11 and iPad. I’ve tried switching off and on with router and devices, clearing caches, removing and loading apps etc but nothing works and it’s getting really tiresome now.
16 REPLIES 16
@Linzi94  when you turn off/on the router are you at least given it 30+ seconds before you turn it back on ?
Linzi94
I think this is the third time I’ve posted this, my wifi is terrible and has been for months possibly a year. I’ve done speed checks and clearing devices and I have no land line hand set. I’m not sure what I’m paying for as I constantly have to use 4G (including posting this) as my wifi is unreliable. I need someone to look at this before I switch provider as I’m throwing money away here.
@Linzi94 , where are you trying to use wifi? Is it near your router or further away, like in another room or upstairs? If that is the case, have you thought of getting repeaters?
Which router do you have?
Are you able to plug something that uses the internet straight into the router to see if that works ok?
What speeds are you supposed to get as that could also depend how good your wifi is?
@Linzi94 : Yes & last time you were offered some help & advice but chose not to respond.
Probably had no internet.
Will try again….
Please do.
BT phone number check says
There is no data available for this number. This could be either because it is not a BT line or it is a new BT number that has just been provided. Most new numbers will appear on the checker 24 hours after BT has installed the line
Speed check
