Pausing Wifi
WolfyWolf
Hi all.
I am trying to find out if there is a way to pause the wifi signal on a set IP at a set time with a wifi 6 EE router.. ie:  192.168.1.246 is set as static to an xbox, I want to stop that xbox from using wifi at 4pm and resume at 5pm, can I do this ?
If not is there any way that I can do it through xbox apps (xbox family app does not do it) or any other way someone knows of?
6 REPLIES 6
@WolfyWolf : Thro' Parental Controls of the EE app.
Cheers but... What app? Where do I find the parental controls?
The EE app I have gives me 5 options, home, shop, manage, rewards, and help, if I click on manage all it wants me to do is buy stuff.
@WolfyWolf Does it pop up once you select manage, you can see broadband, to manage your router and set up groups, parental controls etc..
No, all it gives me is Billibg, Mobile & Sims (Get), Broadband (Get), Gaming (Get), EE Shop (Get), Subscriptions, and Orders
Apparently after contacting EE my app is broken.
@WolfyWolf about link below for parental controls for when the app is fixed.
Using Parental Controls on EE | Broadband Help | EE
