Pausing WiFi on a device group
Piacere
I have recently switched to EE broadband, and having switched off the setting to control the timings for when my children’s devices can connect to the WiFi a while back as my kids are older now, I find myself needing to go back to it for my daughter. Instead of setting a schedule, I would like to just pause the group with her devices in manually whenever I need to. But, she just goes and resets the router and it comes back on again! What’s the point of having a setting in the app where you can pause access if it will just ignore that setting when the router is rebooted. I get that it’s reset, but why can’t it keep the setting when it comes back on?
Maestro
Maestro
@Piacere There is only so much that an ISP can do on a router, what you wish also has problems in reverse if it were to get stuck on a pause for ever, it's time for you to have the stern talk with your daughter about not resetting the router to get round what you have done.
