27-11-2024 02:03 PM - last edited on 27-11-2024 02:56 PM by Leanne_T
My fibre installation was sub contracted to Circet via BY Openreach. I was out at the time, but my wife knew exactly where we wanted the fibre to entre the house.
Instead, Cirect rock up and convinces my wife it would be better installing into the kitchen (i.e. directly where the cable came out from the ground) which is at the furtherst point of the house where we would usually use WIFI.
She was told, if I was to run a 30ft cable around the side of your building it will likely have a serious impact on your speed and you don't want that. He was in and out with 8 minutes.
I complained to BT, Openreach a complaints number was generated then at some point in June I receive a text from a Circet rep manager sho said he was send out one of his engineers to look at in two day. Two weeks, guy rocks up and says I am not allowed to touch the box ( even though they installed it) and said he's report back to Gavin his manager. I tried call / text Gavin, messages were being read but nothing coming back.
A few month later I call Circet speak to a lovely lady who sais she would send out another enginner. No one showed up.
I then try networkconnections at open reach and there recent repose was we don't do new installs and the work would be chargeable rate.  I now have Clive ***** email address and sent him an email.  I was going to leave this one for week before reaching out to Ofcom
I going to go mental on socials and trustpilot, but does anyone else have any other ides for me to get some form of traction on this - This has been appalling customer service
Thanks,
Holiam
[mod edit: employee details removed from the community]
29-11-2024 08:27 PM
@Holiam2024 I can understand that you may not agree with me, but I don't beleive I said anything unreasonable.
But I do wonder if there is a misunderstanding on some of the info, and therefore that appears why you are trying to still get this sorted so long after the event?
I gather you ordered fibre from Cuckoo in Jan/Feb?
An attempt was made to install the service, so I assume that is when the ONT was installed in the current location.
For whatever reason the install was unsuccessful, so you cancelled the service.
You ordered a similar service from EE in May./un which was successful - but the ONT is not where you want it.
At some stage you complained to Cuckoo, but with no active service they were not interested.
So now you are trying your luck with EE.
In-between these events you had a moan to Clive who is/was sympathetic.
At some unknown time block paving was dug up.
At some unknown time fibre was laid and excess was left.
At some unknown time the excess was not used as agreed by your wife.
Lots of other irrelevant info introduced, wire on flats 50 yards away, 10Gb devices, all of your previous installs, your mates opinions and so on, but no admission of your own responsibility for distributing your own data in your own premisses, it all just sounds like more bluster than information that is helping your case.
I really do hope this helps - at the very least think about putting your case in a logical sequence which will then help work out who best can help
Ulitmatley you could fix this with 10m of decent quality ethernet cable.
29-11-2024 09:40 PM
@JimM11 Not quite, the OR team were well aware of what the ask was to the extent they even chalked mark an X on where the ONT was to be fitted leaving sufficient fibre to complete the job. I was told the job card? was clear on where it was to go and that would be past to the next team to install the ONT - which didn't happen, and Circet did take responsibility of this initially before going radio silent.
29-11-2024 10:01 PM
@Mustrum , first of all I'd like to apologise for my tone in my previous response to you. I appreciate this community is people given up their free time to help others with their issues, and I for one appreciate that.
Just for clarity and not going to babble on again - sequence of events
1. I ordered fastest fibre connection from Cuckoo
2. OR send round and did an amazing job of running the cable lifting up cobbled private area on a cold and wet day (I did keep them supplied with coffee and bacon rolls).  OR left c. 40 ft of fibre at the property and placed an X on where the PNT box was to be installed.  I was informed that these instructions would be passed on to the installer.
3. Installer came (Circet), wife went over what was agreed and he overruled these instructions stating speed would be significantly hampered by extending the fibre cable some 30 feet from where it was unearthed. Circet left even though the line was not active and instructed my wife to contact ISP
4. Following day, I call Cuckoo and explain the situation, they confirm issue with backend.  I gave them a day to resolve.
5. In the mean time, I call in to my local EE shop and enquire about their Broadband equivalent, whilst a little more expensive, the discount on the Mobile tariff more than made up for it.  I ask EE if I we cuckoo is unable to resolve issue, and I decided to move to EE, would their engineers be able to move the ONT to the correct location, and I was assured that this would be no problem.
6. Following day Cuckoo still having backend issues, so I cancel, pop back into EE sign up for their offering, was given an installation date from when their engineers would come.
7. Engineers didn't come as they were able to take over the existing line without any visit.
8. From this point on the finger pointing exercise began - this is Circet's problem, you need to speak to EE, you need to speak to BT and so on
9. I have emails from both Circet and OR apologising for the delay and both offering to have this matter resolved.  and then it went quiet today.
Happy Ending
I received a call from OR  relocation team Manager who has confirmed this will be relocated free of charge within the next two weeks.
Thanks to all who contributed
Holiam2024
29-11-2024 10:33 PM
@Holiam2024 I really do appreciate your update, and in turn and as it approaches Christmas I do hope your gratitude extends to the guys who sort out the extension.
I have unmarked your solution, it did not make sense, and was not the solution, I could be cheeky and mark my previous or even this reply as a solution, but leave the choice to you.
I have to say, I am very disappointed with your previous replies, and do wonder why you felt the need to resort to such ways, on the other hand, I do look forward to the help you could provide to fellow customers, Cyber Security knowledge is an easy help for those who know a bit about it.
30-11-2024 09:53 AM - edited 30-11-2024 10:01 AM
Hi Mustrum, I apologise- I'm a newbie here and assumed solution was that the matter looked now it was going to be resolved. Didn't realise it was going to lock the thread.
You are absolutely correct, in the same manner as I did with the OR team that laid the cable for nearly 5 hours picking up cobbled stone and replacing them to the extent you would never know they had been touched - all of this on a windy and very wet day were treated to unlimited tea/coffee breaks, biscuits and bacon rolls.
But as you say, it's festive time, so I may need to festive up my game, but rest assured they will be well looked after.  In fact after 10 months of trying to resolve, I'm likely to hug them and declare my undying love - but would prefer not to have a restraining order our against me, should I need their assistance again.
I'm sorry you feel disappointed, but I think if I was to share all the emails/texts, over the last ten months, you would know why I am a little frustrated. A lot of the time in the event of emergencies, I had to resort to travelling some distance to the office in order to get the speeds I need to be able to be effective in my role. I specialise in ransomware attacks, data breaches, and global threat analysis on suspicious network traffic, I am also qualified in digital forensics and AI, and often provide expert witness services to the courts for anything cyber crime related (Prosecution and Defence).
A great deal of what I require to do during cyber attacks requires me to have fast internet access for obvious reasons or worst case attend onsite.
I would be more thank happy to provide support to this excellent community should you require it and sorry again for the tone of my earlier emails. I'm genually a very composed a polite individual but following an recent incident where I was unable to be effective in my role, I started to lose my patience with so many broken promises and delays
I have 4 desktops and 12 display units, so porting them through to the kitchen was never going to be the right answer.
I want to personal thank you all @Mustrum @JimM11 @Leanne_T and @XRaySpeX for all you comments and advice. I appreciate you all go out your way to help those in need voluntarily, and that speaks volumes.
I will be happy to come back and report when the ONT is in the correct position - I suppose that would be the time we hit the solution button, or did I get that wrong again? if so, it would appear I have a newbies thread that I need to read.
If you don't get a chance to see the update, I would love to wish you all a very happy time over the festive period with you family and friends. Thank again for your support
Best wishes,
Holiam
30-11-2024 10:16 AM
@Holiam2024 As you say, the resolution is in sight and OR will step up and get it done, cuckoo has flown the nest, but looking like it's all going to come together now and you will be a happy bunny. If ever a next time, you have to make sure to be there and stamp your authority to what is needed, i did the same with MJ Quinn OR contractor when he came LATE for the install, wanted to do quick/easy best for him, your having a laugh i said, he said no serious, JOB STOPPED. Did cause a 21 day delay but whatever just wanted it done my way, worst of all was I prepped everything before the install, OR did the second attempt in / out 1hr job done, easiest ever install and got (2 for the price of one as the engineer's) lives 2 minute walking distance from me. 100% they agreed stop was the right thing to do.
30-11-2024 10:31 AM
Lesson well a truly learnt - the OR team did chalk a lovely X where the box was to go and leave 40 feet of additional cable and apparantly instructions were to be passed to the next engineer , so I mistakingly thought this was a slam dunk - but never again. I will be shadowing the ONT installer every step of the way! And next time I will provide him the portable vacuum cleaner do he can tidy up the mess from the drilling left inside the property! I may have to give him a quick demo on how it works, but none the less, he will leave the carpet as he found it! 😁
