Openreach CSP
Anon2024
Hello! I have noticed the cable to the openreach box outside the house for the full fibre broadband (think it's called the CSP?) looks like it has possibly come out - not sure if it's supposed to look like this. Broadband still works and everything though. I've attached a photo of what I'm talking about, and it looks like the large grey cable should be going directly into the box rather than looping round, right? Should I contact EE to send someone out? Is this likely to cause any issues if I just leave it as it is?
Thanks in advance!
@Anon2024  I looks like that’s how it was installed.  It’s a poor job at that as the fibre cable shouldn’t be open to the elements because anything can catch that cable and break it.    Personally I would call.
Anon2024
Thanks for the reply. The cable isn't stuck to the wall like that, it's completely loose that's why I was unsure if it came out or was installed like that. Stupid question, but do you think they would charge to come out and have this fixed? If so, not a large amount I hope!
Should be free as it's their property & you haven't accidently damaged or vandalised it.
