ONT Los Red Light
AB4Life
Hi all,
My broadband has gone down for the first time in 3 months being with EE. Well this is the first I've seen the red los light on the ONT which I assume is total loss of service. Does this need an engineer visit?. Also tried powering the ONT on and off a few times even doing the reset with a pin but to no avail. I did a broadband test with service checker and it says there's a problem with external communication and won't be fixed to 8th July. I'm not waiting that long.
Any help much appreciated 🙂
1 ACCEPTED SOLUTION
Community Hero
Community Hero
@AB4Life Yes, OR will be required to have a look to see were the fibre signal is not reaching your ONT. I assume the service checker test has responded back to you and 1st available fix date you will have been given is then. HTH with the time that you reported could also be some maintenance going on hope that is the case and you are back up and running.
Community Hero
Community Hero
Hi JimM11,
Thanks for your reply and it's back up and running. I rung EE this morning and after being passed back and forth it come back on whilst being on hold. Anyway I'm glad it is back on.
Thanks agen, take care 🙂
