New EE Hub not connecting to Aurora AOne Hub
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 11:14 AM
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 03:36 PM
It is not a BT router. It is the EE Smart Hub Plus SH32B.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 03:38 PM
@NAEW1 You are being asked what BT router you HAD before the EE one now!!!!
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 03:39 PM
Sorry...it was the BT Smart 2 hub
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 03:44 PM
@NAEW1 ok thanks.
The reason for the question is that router will work on EE, although you may need to log into it and change port 4 to a WAN port rather than a LAN depending on the version you have.
Could you try using it and connect up the AOne to the BT hub, and then take a note of the port settings if all works?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 03:47 PM
The only problem is we have sent the old equipment back.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 03:56 PM
Ah ok, I thought this was a recent change from BT and you would still have the BT Hub. Always worth keeping the old hub until you get everything working on a new one!
Is the AOne connected directly to the EE Hub? Not through a switch or Powerlines? How long is the cable
I think you have already changed the ports and cable?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 04:00 PM
I agree lesson learnt...I should have kept the BT Hub! The 1 meter ethernet cable is directly wired into the router and I have tried 3 different ports. I have also used two different cables.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 04:14 PM
@NAEW1 have you done a factory reset of the AOne whilst it is connected to the EE Hub?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 04:16 PM
I have done a factory reset of the AOne hub whilst connected to the EE router.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
21-09-2024 04:22 PM
Other than trying that again in another port, not sure what else I can suggest at the moment.
Did not have this issue with my Hue Hub, and Alexa controls Zigbee lights for me.
