Network keeps dropping
fast7rax
So we are new to EE and could only get upto 16mbps as only part fibre…we have a wifi6 box and the connection keeps dropping..
I have my PS4 connected via wire which works well as long as nobody connects to Wi-Fi 🫣 as soon as someone connects to Wi-Fi the net drags real bad and the ps4 starts buffering and loses connection..practically impossible to connect phone and use Wi-Fi as it’s so bad so having to top up phone and pay a fortune for mobile data..
Any reason or help as to why it’s happening? If it doesn’t get better I will be forced to leave and rejoin  Virgin just reluctant to pay there prices.
thanks
John
@fast7rax  recommended minimum speed for gaming is 25Meg 16meg is slow so when gaming and when someone is trying to also use the WiFi it will impact it heavily.   That 25Meg is also just for gaming not anything else at the same time.,
The modem does not do anything different regarding lights..we use the ps4 just to stream YouTube and as soon as we connect a phone for example to the Wi-Fi and open a webpage on the phone YouTube on the ps4 will start buffering or lag out altogether and the Wi-Fi just hangs for a few mins..it’s barely impossible to use the Wi-Fi if the tv is on via the ps4.
It’s not even gaming it’s used for streaming YouTube
