NAT settings
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
02-10-2024 02:52 PM
Hi
is it possible to change the NAT settings in my EE smart router for my Xbox, as it is set to moderate?
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
02-10-2024 03:13 PM - edited 02-10-2024 03:14 PM
@Beatmouldon the quick answer is no. There is no such setting in the router.
Make sure you are directly connected to the router, ideally via an ethernet cable, and not via powerlines or WiFi extenders.
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
03-10-2024 04:35 PM
@Beatmouldon if you go into network settings on your Xbox and then over to test Nat type after a couple tests you will see your Nat type change to open 😊
Smart Hub Pro
- Mark as unread
- Bookmark
- Subscribe
- Mute
- Subscribe (RSS)
- Permalink
- Print this post
- Report post
04-10-2024 02:49 PM
This worked perfectly. Just got the Smart Hub pro wired to the Xbox via a switch from the hub. 3 NAT tests and it went from moderate to open. Thank you!
- BT basic email and Outlook access settings on transfer to EE broadband in Broadband & Landline
- Port forwarding in Gaming
- Does the EE SmartHub (Black) Firewall work in Broadband & Landline
- Smart Hub Pro and IPV6 in Broadband & Landline
- I have a heat pump and use the ONECTA app. in Broadband & Landline
