My Wi-Fi has become unbearably slow since yesterday
imacken
I have 1Gb speeds to the Smart Pro hub, and I have 2 Smart Extenders.  Everything has been great for the last few months, until today.
I was getting 500-600Mbps on my iPhone and other devices in the rooms where the extenders are located.  Today, one of my extenders has gone from a solid Aqua light to Amber, and on both I am only getting 70-100Mbps.  This is making large downloads pretty painful.
I've tried re-booting the router and the extenders, but no change.
Anyone got any suggestions?
Peter_W
Thanks for giving that a shot @imacken .
We definitely can't rule out the possibility of a fault with the device, especially the one that's showing the orange light.
It's definitely worth giving our Technical Guides a call, as they'll be able to run more specific diagnostics, and if needs be arrange a replacement.
Peter
10 REPLIES 10
Peter_W
Hey there @imacken 😊
Is it a solid amber light or a flashing one you've noticed on your Smart WiFi device?
Solid would usually indicate that it's connected, but could do with being moved closer to your Hub to guarantee the best connection.
Flashing on the other hand means that you'll need to re-pair with your hub via the WPS button or an Ethernet cable.
It's definitely worth checking out our help article on this too.
Peter
imacken
It’s a solid amber that has always been solid aqua until yesterday. Just a symptom of a general downturn. Even in rooms with a solid aqua extender speeds are down to about 70Mbps when they were 500-600 before yesterday.
Something has happened.
Peter_W
Thanks for confirming that, @imacken.
What speeds are you getting when connected to the main hub, and have you tried a wired connection to see if these speeds are affected?
Peter
Gr3z
The exact same has happened to me, I have three extenders all were aqua was get around 400 to 480 every in the house and about 280 in the garden, now I get amber light and around 120mb, if recycle my WiFi connection on my phone  to connect to the main hub  and stand by it I get I get the as expected 500mb
They were great for a week or with Stella speeds. It’s like there has been  some smart setting applied and messed it up.
I also have one extender with a different  firmware version that won’t update 😔
imacken
I am getting very good speeds on my phone, i.e. 700-800Mbps, if I stand very close to router.
Both extenders speeds still stuck around 100, when used to be 500-600 for both previously.
Peter_W
That's good, @imacken
It definitely sounds like it's the extenders causing the rub here in that case.
Have you tried re-pairing these since the issues occurred to see if this makes an improvement?
Peter
imacken
So, today, the speeds are back to around 500Mbps on the extenders, even though one of them is amber when it used to be aqua.
Peter_W
I'm glad to hear things have picked up a bit here @imacken.
With the Amber one have you tried moving this closer to the Hub or trying to re-pair this like I mentioned yesterday?
Peter
imacken
I can't really move it any closer and keep it in the same room.  I think what concerns me is that I feel it is symptomatic of the issue that the extender is in the exact same location it has been solid aqua for many months.
I did re-pair the 2 extenders yesterday, but at the time it made no difference.
