on 14-10-2024 10:58 AM
I have just upgraded to full fiber with bt/ee I can’t plug one of my two house phone into hub as I’ve no spare wall socket what can I do
Solved! Go to Solution.
on 14-10-2024 11:39 AM
@Ryanbradley I believe you can get an adapter that plugs into the mains and then connects to the router via the Dect service so you could plug the second phone into that.
Or if you know anyone with some basic telephony knowledge it is simple enough to use you existing wiring after the old phone service is disconnected.
