Landline
Jaie1
Hi there I just wanted to know if I get broadband with no landline will it get rid of my homophone number that is on sky
Mustrum
@Jaie1  do you also have broadband with Sky?
But yes, chances are, unless you also move your landline number to EE Digital Voice then you will lose your Sky Landline.
Yes I have broadband with them is there no way of getting ee internet with out that happening
@Jaie1   No.   It’s the same line for both.  You could pay to have a 2nd line to your home providing there is room at the cabinet for this new connection.
@Jaie1 Sky's broadband to the home has to have a number associated with the connection, with EE you can get home broadband only and drop the landline number completely. The physical cable from OR to the home will deliver the broadband, if you do not wish to use this method then mobile internet would be the other way and i depends on how good that signal is from the mast to your home. HTH
No, if you remove your BB from Sky, it also removes the landline. Sky doesn't allow you to have landline only with them.
