25-02-2024 06:19 PM - edited 25-02-2024 06:21 PM
Is it possible to keep my landline phone if getting FTTP installed? If so, which package do I need to select? I want the 900mb FTTP.
Also, does it have to be installed by a cable or can it be installed connected to the telegraph pole? A different provider advised us against their cable installation as there would be too much drilling and concreting and suggested we get fttp from a different provider from the telegraph pole instead.
26-02-2024 03:46 PM
Sorry that was a problem with my broswer.
@Coz21 yes that means you're service will come from a pole and the engineers will need to use a hoist to help them with the installation.
Neil
26-02-2024 06:01 PM
Coincidentally, my next door neighbour was having broadband installed today by Open Reach (not sure which kind, I'm guessing fibre of some kind) and they were up a ladder connecting it to the pole. They had to abandon the installation though as her electric went off.
