Lag and intermittent speed isdue
Adam1968
Hi I've had intermittent speeds and bad lag gaming since I joined ee from bt. 6 months of nightmare. I had extenders sent but I should fought harder six months ago but in last couple weeks I had enough started demanding it be fixed.
We got an ee qube engineer out who plugged into master socket found pings over 300 packet loss etc so he said needs openreach engineer. We had two engineers from broadband side who find no fault blaming ee network. I'm waiting on more help as am sick of this problem. Can you tell me what can be done to fix this as qube engineer gets problem I do when I game or checks speeds which go up and down from 72 Meg down to 5 Meg up and down all over place and impossible to game online.
26 REPLIES 26
Christopher_G
Hi @Adam1968
Welcome to the community.
We have a few broadband experts here in the community who may be along with some suggestions soon. My only other advice is to continue to speak with our technical support team so they can look into this further for you.
You would be getting the same connection from EE as you would have been from BT if changed your BB like-for-like.
Adam1968
Keep talking to tech side my fault going no where.
EE Cube engineer came over week ago plugged his laptop into the master socket eliminating any problem my side. He found packet loss and pings over 380. He said there is oviously a big problem and needed an openreach engineer.
Two engineers came out plugged there devices into socket says sync at 80 Meg and no fault.
Cube laptop was seeing what I was getting as I played online games I was experiencing lag issues in game so I'm glad the cube engineer back up my problem by seeing packet loss and high pings.
Now tell me why the cube engineers laptop tests show this side that I have fault but openreach broadband testers using a different device see no fault. Yes they she it sync at 80 Meg but if there packet loss and high ping doesn't matter what he sees it's no use for a gamer. Times it shows sync at 80, but drops to Meg or 25 50 upwards and can change but sync at 80,. I feel the ee help desk no idea what to do next. The openreach side say line fine and if there is packet and high pings it's EE network that's at fault. My fault not being fixed at moment waiting on another team as had three engineers got four days but not called I'm sick of phoneing. My fault not bring dealt with
Sorry for typos this stupid predictive changes letters
Mustrum
@Adam1968   never mind the typos, rather than repeat your first post, could you provide the info requested by @XRaySpeX  ?
router screenie first then bt Broadband Availability Checker
www.thinkbroadband.com result  https://www.thinkbroadband.com/speedtest/1680109430406580555
can vary as ihave done bt wholesale during day and been down as little as 5 15 40 andupto74. when did speed tests as a bt customer  with bt i was always consistent 80 82 it never dropped speeds once during test been consistently variable with ee since i joined 6months and my 2 children are gamers to and moan consistently why did i leave bt because they say ee always been terrible .is this a coincidence or what ?  can u explain why cube engineer results show packet loss and pings upto 380 saying speed drops during test but openreach bb engineer different test he happy and blames ee network
Mustrum
Looks like your broadband is doing OK at first glance, to find out more about your issues more info needed.
The cube guy is unlikley to have much of a clue on the application/game you are having issues with, so his easy answer is to agree you have lag. Openreach will test your broadband which, apart from a drop 2 days ago look ok.
So, in more detail what issues are you having? How do you get lag, what are you connecting from and to?
Where is the app/game based?
What are you using to test with and where do you get your figures from?
i followed XRaySpeX to get those results why was hesitant in ON SPEED tests as people think look s ok when its not.
are you presuming the engineer just turning up and agreeing with me so he not doing his job and is clueless? i just know all three of us on different top end gaming pcs find games very laggy at times and at other times speeds go way down when test bt always consistent didn't even drop by 1 . I never knew  i had packet loss the cube engineer told me that with his results he showed me his pings over 380 said should be under 60  i just know i hate ee network . i am an online gamer of 24 yrs and can build my own systems . guys at ee never heard of your profile being remapped which bt do remotely .i only know since i left bt i have problems . i had bad issues with sky bb once in past and left them too , no idea what bt does that everyone else is not . but im paying for a terrible service .
Mustrum
@Adam1968   I am not presuming anything, just looking for information or evidence of the issues you are experiencing.
This forum  is not Customer Services, no one on here has access to your account, nor can see what has been reported by engineers or the Broadband care team.
If you don't want to share details there is not a lot we can do..
I am not a gamer, but am aware some ISP's do have gamer profiles, but I would have thought you would be more aware of who offers them than I do.
