Issues with broadband
Tracey2002
I’m having lots of issues with my broadband.the hub says I’m connected but my devices say different.it constantly disconnects,if I am able to connect,it’s pretty slow and the buffering.yesterday I’d say I lost connection at least a dozen times.I wish I’d read the reviews before I switched.any advice would be appreciated
Mustrum
Hi @Tracey2002
Have you recently moved to EE?
Which router and service do you have?
Is it just Wi-Fi connections you have issues with, do you get the same with wired connections.
As for reading reviews, EE's broadband is as good as any other ISP using the Openreach infrastructure, and the troubles people have are likley to be the same with any ISP.
Have you spoken to the Broadband Support Team?
2. Try both a wired & a wireless speedtest here http://www.thinkbroadband.com/speedtest.html . Click on the "Results Page" button at the bottom of the graph you first see and then copy to here just the "Link to this result:" link that you see below the next main graph.
