Internet Problems - Can't wait to leave
Alex_morey1999
Ever since having EE broadband we've had nothing but problems. We've NEVER had the "guaranteed speeds" and it has only gotten worse over the years. Complained numerous times and they "can't find the issue". What sort of company does this because i think it disgusting. I can't wait until my new provider is ready and I will be cancelling EE. I will not be paying a cancellation fee, as your customer service has told us if we don't get guaranteed speeds for 30 days we won't have to. Truly can't wait to leave. Yes, this is a complaint.
