EE Router
Gill591
Hoping someone can offer advice.  I would like to find out how old my EE Router is.     It looks like a EE Smart Hub (just looking at images online).
I have looked at my EE Account and I cannot find anywhere that tells you exactly what router you were sent by EE so that I can determine how old it is.
I have recently checked my broadband speeds (which.co.uk/speed-checker) and the download & upload results were very low.  I had shut down all  devices eg mobile    and my computer was connected via the ethernet cable so I think I did the test correctly (I am generally at sea with technical stuff).    I am going to run the test again a few more times over the next few days to collect more information before I tackle this with EE.   My router is in the best position next to the Openreach box and  connected directly the computer, it is always switched on, I have cleared my browser cache - trying steps to ensure it is isn't the set up in my house that is slowing down the signal.
7 REPLIES 7
@Gill591 : Welcome to EE's Home Broadband Forum.
The EE Smart Hub is the current issue for EE Fibre BB.
Northerner
Hi @Gill591
What speeds are you expecting from your package?
Hi Northerner,
My contract says download speeds between 35.5 Mb/s and 36.4 Mb/s    and  upload speeds between 8.2 Mb/s and 9.1 Mb/s.
The Which.co.uk/speed checker results were
Response 148ms    Download 9.4 Mbps    and  Upload   2.4 Mbps
Hi XRaySpeX,
I struggle with technic etc.  I have been looking through EE Broadband Account and I cannot find any information on my router.  Does my router have a separate account and if so, can you please advise where I find this?
No, your router does not have its own a/c. It is just a bit of kit to enable your BB. The most you would've had is the Welcome emails when you took out your BB or were sent a replacement router.
The age of your router is unimportant. I've never seen a router whose age has a bearing on your BB performance. That is affected by the quality of your line & its connection. That can only be investigated by looking at the actual connection stats experienced in real time by the router itself & compared with the best estimates of what you should be getting. These I have asked of you & w/out them nowt more can be said by anybody about the speeds you are actually getting.
Hi XRaySpeX,
The information above has been useful.  I found a green Welcome to EE Smart Hub user guide and I have printed off full router stats.
I have  done speed tests on Thinkbroadband & BT Wholesale - the results were far better than the Which.co.uk/speed checker (which I have run a second time - still getting same poor results?).  I have also found the BT Wholesale Broadband Availability Checker and printed off information based on my landline number.
Most of above goes over straight over my head and I haven't posted on here because I don't now how to - it is taken me ages to work out how to find my initial comment on EE Community after I left the forum.  However, all of this has given me a starting point from which to move forward.
Good! May I see them? Use the Camera icon above your text to upload an image file to here.
