Information: Smart Hub Parental Controls not working properly with some browsers
Ben570
Hi community,
This is an informative post more than a question. I have been having issues with parental controls not blocking adult websites including those with obvious related words in their names, (e.g. p***hub.com) and EE have been investigating for a number of weeks now.
They have provided a workaround while they are looking for a proper fix, but essentially it comes down to newer versions of browsers like Edge or Chrome having a  new experimental feature called TLS 1.3 hybridized Kyber support enabled which breaks the parental controls feature. My loose understanding is that this is because the feature uses a new type of cryptographic algorithm in the browser session that makes it more private and instead of getting the EE banner *Access to this website has been blocked* page, the browser will display its own inbuilt "The connection for this site is not secure" page because EE's parental control systems can't intercept it properly. However, with TLS 1.3 hybridized Kyber support enabled (which it is by default in the latest browser updates) the user can hit the refresh button repeatedly until the browser complies and loads the site that should be blocked.
I am putting EE's workaround here as I understand it is not just my account that is affected, but likely anybody using this the parental controls may be affected. The current workaround is to disable this experimental browser feature as follows:
1. In your browser, type or paste the following setting URL into the address bar and hit enter: chrome://flags/#enable-tls13-kyber
2. Change the TLS 1.3 hybridized Kyber support flag to *Disabled*.
3. Close and re-open the browser.
Best of luck.
52 REPLIES 52
@charlienormand That is not the latest version reported so you are 1 version back, so the info you got was correct and you were possibly updated. Network and system uptime you can work it out when if you have NOT been resetting yourself. Link below to the reported page.
Digital Voice issues - Page 19 - The EE Community
JordanTA
EE Knowledge Specialist
Hi, apologies for the delay. There was an update pushed out to around half of our SH3s (Smart Hub Plus) which fixed the issue. But this then caused an additional bug with TV Mini Boxes.
The update however is now going ahead, so hopefully this will be pushed out ASAP, I've been told the rollout will continue throughout the rest of the week.
@JordanTA : What's an SH3? Does '3' = "Plus" or "Pro" or "31B" or "32B"?
JordanTA
Updated, cheers
Conan_matrix
I’m now on EE and I’m getting the same issue. We’re a year on from the original post so I don’t understand why it is not fixed. The BT Parental Controls do not have this problem so there must be an easy fix. Especially, as BT/EE are the same company!
@Conan_matrix BT and EE are not the same company at all! Both have there own way off doing things, yes they are owned by the BT Group but there it ends!
@Conan_matrix  - as far as I can tell, the issue concerning the TLS 1.3 hybridized Kyber support browser flag has been resolved. It certainly seems to be working from where I'm sat. @dellybeanhead @Ben570 - any views?
Perhaps you have a different problem?
Actually, it does look ok now! Switching on Safesearch as well as Parental Controls has done the trick.
I had my sons parental controls on… and assumed all would be safe and well. But to my horror I’ve just discovered he’s been accessing porn and him and his friends have been sharing links, videos and images amongst themselves. Utterly disgusting. He is only 13!!!!  Why has this control not worked??? It was meant to block adult content !!! I am so very disappointed and angry about this.
