08-02-2026 12:10 PM
I'd love to hear if anyone can validate this -- I've been fighting with an iOS power drain issue, but in fact it's actually a IPv6 issue which occurs both with the EE Homehub AND with a opnsense router. Basically it seems as if the EE network is breaking path mtu discovery both by dropping fragments, and in not returning the correct ICMP responses.
This is quite technical but it's quite a fundamental issue (it feels to me as it's a 'broken network'). Of course I may have made an error:
More complete AI-summarised version below.
Observation: The upstream network (EE/Openreach backhaul) appears to silently discard outbound IPv6 packets that require fragmentation. This breaks Path MTU Discovery (PMTUD), causing connectivity stalls and high battery drain on devices attempting to negotiate packet sizes (e.g., Apple devices using iCloud Private Relay).
Context: ISP/Plan: EE Full Fibre 900/110. Hardware: Tested on EE Smart Hub Plus and confirmed consistent on OPNsense (Intel N100). MTU: Link negotiates at 1492 bytes (PPPoE standard).
The Limitation: The network accepts unfragmented packets up to the link limit (1492 bytes) but drops any packet that is fragmented, regardless of total size. Crucially, it fails to send back ICMPv6 Type 2 (Packet Too Big) or Type 3 (Time Exceeded), creating a silent "black hole."
Test Methodology (Reproducible)
You can replicate this on any Linux/macOS device (Pi, Mac, etc.) connected to the router. You need two terminal windows open.
Step 1: The Monitor (Terminal A) Run this to listen for "Packet Too Big" or error messages from the ISP.
sudo tcpdump -n -i any "icmp6 && (icmp6[0] == 1 || icmp6[0] == 2 || icmp6[0] == 3)"
Step 2: The Trigger (Terminal B) Run these pings to test the boundary.
Test A (Standard Packet - 1492 bytes): Payload 1444 + 48 bytes headers = 1492 bytes (Fits in one frame)
ping6 -c 3 -s 1444 ipv6.google.com
Result: Success.
Test B (Fragmented Packet - 1493 bytes): Payload 1445 + 48 bytes headers = 1493 bytes (Forces fragmentation)
ping6 -c 3 -s 1445 ipv6.google.com
Result: 100% Packet Loss.
Step 3: Verification Look at Terminal A. Expected Behavior (RFC Compliant): You should see an ICMPv6 error message. Actual Behavior (Black Hole): The terminal remains completely blank. The packets are dropped silently.
11-03-2026 08:39 AM
Are we saying the issue does not arise to all destinations then? Shouldn't this be an all or nothing thing if v6 PMTU is universally broken?
Is it also the case that your testing doesn't conclusively prove where the v6 ICMP Type 2 messages are going missing, or am I misinterpreting things?
If you were to jump ship, I think it would definitely be sensible to check the situation with the destination ISP first (if you can) to avoid disappointment!
16-04-2026 08:44 AM - edited 16-04-2026 08:46 AM
I cannot reproduce this issue now. EE have got back to me - after escalation I was able to correspond with one of the technical experts. Some testing has been done, and the ICMP Type 2 Packet too big responses are correctly generated.
Sincere thanks to those involved!
Why not before - user error? Something changed? I'm not sure -- but can confirm all is now working well
Feel free to message here if you need more information.
The original repo is also updated with a summary. planetf1/bt-ee-ipv6-blackhole: Investigation of EE FTTP (residential) missing ICMP type 2 packet too...
16-04-2026 09:05 AM
Thanks for updating the thread. Previously, a few of the sites failed when using your script. They are now all working fine for me (apart from AWS and HuggingFace, which as you say seem to be affected on all ISPs).
Glad to see it is fixed on EE now.
