I've been with EE for many years my contact was set at an agreed price somesignI
tonythompson195
My agreed price monthly has been increasing for sometime now , I've been with EE for many years and have recently retired from work so I'm feeling the pinch somewhat can you make any suggestion to help also my router is playin up lately buffering losing the signal more frequently etc it's extremely inconvenient and frustrating I believe the router is approximately over 5 years old will it be possible to attain a more modern router that is much more reliable ? I have been very loyal to EE over several years so would appreciate any help 🙏
Your BB plan is subject to an annual CPI + 3.9% increase (14.4% this year)  that you agreed in your contract that is applied each year from 31st Mar. - see HOME BROADBAND CPI PLUS
