I am not getting the minimum promised fiber broadband speed!
gtunc
Hi there,
As title says, I am not getting the minimum promised fiber broadband speed! What shall I do?
I followed all recommended steps to check if there is anything wrong with my current setup, but everything looks normal and I am getting 35-40mb maximum (not around 60mb as promised).
How can I contact EE?
Thanks.
10 REPLIES 10
gtunc
Hi there please find my responses below:
1.
2. I tried with wire and the speed was 45mb
3. BT didn't recognise my phone number then I was able to find my address but it was showing me this message below:
Your address has been successfully matched; however we cannot determine ADSL availability at this address. Please try the Telephone Number or Postcode Checker.
2. No, I need to see the graph of the speedtest. Just post the link that is displayed.
gtunc
Here's the link and the screenshot, this time it was a bit up:
https://www.thinkbroadband.com/speedtest/1653403938742325855
Mustrum
It may be worth having a re-read of @gtunc  thread from a couple of years ago.
https://community.ee.co.uk/t5/Archived-Posts/Suddenly-I-started-getting-lower-broadband-speeds/td-p/...
gtunc
Yes I read that but why shall I pay for "at least" 60mb speed and get less than that? Then they should give me discount if they can't give me "at least" 60mb.
Mustrum
According to your router stats above you are getting 62Mbps.
Things have obviously changed since your post a couple of years ago, but many of the issues seem to be down to your misunderstanding - I. thought bringing it up would help save some time.
gtunc
Where do you see 62Mbps and what am I understanding wrong?
Mustrum
@gtunc  In post 3, your router stats show a sync speed of 67Mbps (sorry not 62).
Speeds quoted by ISP;s are sync speeds to the router, not speeds tests via WiFi which they cannot control.
