High upload latency
benonwheels
Hello,
I am using All-Rounder Fibre 67 broadband with a BT Smart Hub 2, wired internet. Over the past few days my upload latency has become extremely high and has made online gaming on my PC fairly unstable. It's particularly noticeable while I'm playing a racing sim called iRacing which has a live meter box that shows things like latency, connection quality etc. Most of the time it shows the latency at a good level, but will randomly spike every few laps and according to other drivers around me cause my car to lag/blink for a few seconds before returning back to normal. Running the Ookla speed test and bufferbloat test suggests it's not just specific to iRacing though.
I have tried resetting the router, unplugging and replugging everything in several times with no success. Unfortunately I have no way to use the EE app diagnostics as I'm using the BT hub so nothing broadband related works in the app. When I switched from BT to EE last year I wasn't sent a new router, only a new TV box. My speeds are exactly as promised and remain super stable, it just seems to be a latency issue. I have made no changes to anything, the issue just randomly started a few days ago. I am on partial fibre as full fibre is not available in the tiny village I live in and won't be for the foreseeable future. ☹️
Not sure where to go from here and not super proficient when it comes to internet issues. Any help would be greatly appreciated.
Maestro
Maestro
@benonwheels Having an EE or BT hub does not stop the diagnostic function from working, HELP to 66033 gets that done.
Use the link below to test how good your connection is. Extend the time for longer period and everything else as is.
(1) Re: 1.6Gb keeps fluctuating between 0 and 1500Mbps - The EE Community
I did that, but when prompted use the online diagnostics to report a fault it would just link me back to the app.
I then tried to do it via the website and am still unable to do anything.
Thanks for the connection test link! This suggests that everything is fine? I ran the test several times and got basically the same result each time. I also just ran a 30 minute session of iRacing with no latency issue and steady ping. But the speedtest and bufferbloat tests still tell me my upload latency is high.
@benonwheels Sure looks good, designed to hammer the connection rapid as it can, no lose or no delay's so looking good, can be an internal device on your network that butts in and slows the response down and produces ping latency so do keep that in mind, easy to prove all devices off and test, then on one at a time... Range off buffer bloat's linked from previous going to go find. Was a while back for me though.
Re: Upload Latency - The EE Community
@benonwheels If you need it also handy for continuous running.
https://packetstats.com/
