Hub Manager Beta missing functions
Nick-V
I will have to change supplier if the new Hub Manager (currently in Beta) continues to omit functionality present in the current Hub Manager:
1) It does not seem possible to identify online devices
2) It does not seem possible to see devices by connection port
I hope that these important functions have not been omitted as they are vital to the way I operate.
Regards, Nick
bobpullen
Star Contributor
Star Contributor
Huh? You can identify online devices under the 'Devices on your network' section, or am I missing something?
What do you mean by 'devices by connection port'? There's a filter under the same section that shows devices by interface. Are you saying that you can't see which of the physical ports an Ethernet device is connected to? If so, I'm curious: why is this useful to you?
I am using the beta version newly available for us to try. Are you?
In the old version I can identify online and offline devices separately. I can also see devices by CONNECTION INTERFACE.
