30-03-2024 04:02 PM
I have just switched from Virgin Media to EE. I am on the Essentials Fibre67 package.
With Virgin Media I was able to put the hub into modem mode to then run my linksys mesh system. I have tried looking for this functionality with the EE hub, but cannot find it and after looking on this forum i see many responses saying it can't be done, you can only switch off the wifi. I have tried that, but my linksys app is stating that no internet connection is found. I still have my VM hub and line live and when i re-connect Linksys Mesh to that, i have no problems, so i can only assume that the issue with the EE Hub
Not at all experienced with this stuff, so any help on what i could try or what I'm doing wrong would be really helpful. I'm still within the 14 days cooling off and as my house has solid walls throughout, I need the mesh system, so if not possible, I will have to cancel and go back to VM.
Thanks,
Tim
