How much data am I using?
bamber2000
I have an unlimited data plan at home.  I want to know typically how much data I use.  This is because I will be going abroad and will buy a temporary e-SIM for a week.  I need to know my typical data usage so that I can make a good choice.
I went to My EE but the information I want isn’t there.  Please, how can I get this information?
EE Smart Hub Plus with fibre to the premises.
SIM only monthly plan with unlimited data.
Leanne_T
Hi there @bamber2000
Thanks for posting on the community.
If you have an unlimited data plan, the EE app won't give a breakdown of how much data you've used.
Please follow @bristolian's advice if you would like to keep track of the data usage.
Thanks 🙂
Each monthly bill shows your data usage that month.
Otherwise you're reliant on your device's data counter, synched with your bill cycle.
Your mobile router should have a Data Used counter but I'm not sure if it can be set to a specific period.
bamber2000
I’m sorry.  I wrote my question poorly.  I was referring to my mobile data here on the UK.
@bamber2000 : It wasn't what you wrote but where you posted it. You don't have mobile broadband.
Leanne_T
Thanks 🙂
