18-08-2022 10:13 PM
I have a new router - TP Link - which supports WiFi6. How do I turn the EE modem into a bridge so that the new router becomes the 'leader'.
Thanks!
18-08-2022 10:46 PM - edited 18-08-2022 10:50 PM
Ah Ok, if your openreach box has lights on it, I presume you mean FTTP - Full Fibre.
In which case, if you can set up your new router with PPOE, then you can just connect that direct to the ONT - white Openreach box, and off you go.
Edit link to help page
You will just need your EE Broadband Username and Password -there is a help page showing how to use your own roter that explains it all.
18-08-2022 10:28 PM - edited 18-08-2022 10:29 PM
Which router do you have? And which service?
You cant do that on the recent ones.
18-08-2022 10:40 PM
The router it's called EE Smart Router and it's plugged into the openreach box. The conection type is called "
External (FTTX).
