How do I change ee smart hub from 5GHz to 2.4GHz
daifisher
How do I change ee smart hub from 5GHz to 2.4GHz... I need to connect some bulbs... then change it back again...
If anyone can help please...
For an EE Smart Hub, but not an EE Smart Router, try separating the wireless channels. On the Advanced / Wireless Settings page of the SH there is a button near the top to Separate the Bands. Turn it ON. Then the 5GHz SSID will appear starting with "5GHz-" & the 2.4 GHz SSID not starting with "5GHz-". Then connect your devices to the 2.4 GHz SSID if they can't do 5GHz.
17 REPLIES 17
Is there a way to do this on the EE Smart Router please @XRaySpeX ?
@Staceys_Mom : Maybe by phoning CS to do it for you from their end.
Sorry where can I find this : On the Advanced / Wireless Settings page of the SH there is a button near the top ? Is it in the normal login page ? Thanks H
Well, it's the normal login page of a router. Login to your EE SH at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router.
Everything is to the letter until I try and save it. Then it says saving…. Stalls and then quits causing me to reset the system on the box.
James_B
EE Community Manager
Hi @Jjhjr,
Which router are you using?
I think it's the EE Smart Hub. It's got black ears and has two semi -circle lights on the front. When I log into the Smart Hub dashboard it says EE Smart Hub. So... I guess that is it. Right?
@Jjhjr : Don't sound like it unless you've got it upside down & what you call "ears" are feet. The 2 lights at front are just slightly curved slots. Post a pix of it.
