How can I use my laptop without Wi-Fi at my workplace?
Emmashea16
Hi, I could really do with working on some online college assignments in my lunch hour at work however we don’t have Wi-Fi at the small shop I work at, is there a way round this?
8 REPLIES 8
Northerner
Hi @Emmashea16
Tether to your mobile phone.
Emmashea16
How do I do that please? Is it like using a hotspot?
It is a hotspot.
James_B
EE Community Manager
What type of phone are you using @Emmashea16?
@James_B  I have an iPhone (13 I think)
James_B
Thanks @Emmashea16
To activate your hotspot, go to Settings > Mobile Data > Personal Hotspot.
You'll then just need to supply your laptop with the password and you're all set.
Hope this helps. 🙂
Thanks james this will be great if I can do it as I get loads of data in my allowance 😊. how do I get it to connect at the laptop end? Do I go into settings on the laptop and look for a network or something?
James_B
What type of laptop is it @Emmashea16
If it is Windows, just click on the WiFi indicator at the bottom of the screen and select your phone's hotspot name, you'll then be prompted to enter the password.
Hope this helps.
