Home internet
Camey999
Hello
We have very slow (1 to 1.8 Mbps) landline internet for the last 15 years, despite promises from Openreach to upgrade to superfast we still do not have a date when we could get faster speeds as we live out in a rural area.
So my question is can I use, or pay extra, to use the EE mobile network for home broadband use on our PC's  with unlimited data?
Thanks for looking.  John
Mustrum
@Camey999   if you enter your postcode and landline number in the EE Broadband Deals site it should let you know the speeds you will/should get via your landline but also via mobile broadband.
https://ee.co.uk/broadband/broadband-deals?s
@Camey999 : Welcome to EE's Home Broadband Forum.
