on 22-12-2025 02:22 AM
What’s with the 192.168.1.254 gateway when everything defaults to 192.168.0.1 ??
this is causing no end of issues including solar inverter connection.
EE finds it amusing to put the router settings on a light grey background and white writing??!!
like small print they don’t want people to read.
I am so sick of this. Also, updates to router seem to default settings back if you change them??!!
EE? Never again
on 22-12-2025 02:20 AM
Same issue here
also? What’s with the 192.168.1.254 gateway when everything defaults to 192.168.0.1 ??
EE? Never again.
im going to repost this answer after thinking as I want others to see.
22-12-2025 05:08 AM - edited 22-12-2025 05:09 AM
It shouldn't do unless you've changed the DHCP Config.
Which can you login with to the router? Show your Advanced > My Network > DHCP Config page.
22-12-2025 12:42 PM - edited 22-12-2025 12:42 PM
Hi @Leosmad
Maybe worth considering buying your own router.
