Full fibre
AlanP47
Hi, just about to switch to full fibre as current part fibre bill too high. My concern is whether I'm likely to have to run an ethernet cable half way round the house to enjoy all smart TV features. Have to do this at present but the router is near the TV. If I go with full fibre it won't be. Any experiences good or bad would be good to hear about. Thanks
Community Hero
Community Hero
@AlanP47 If you wish to have a reliable connection then you will just not ever beat an Ethernet cable, it's that simple! Fibre helps with the speed and the delivery but it's no magic pill for a wireless wifi connection!
If your current position off the EE Hub or BT one as you do not say is currently working well, giving you all that you need speed wise etc, then leave it were it is, and Ethernet Cable the ONT to the Hub!
