on 14-01-2025 10:21 PM
Hi i have EE Full Fibre 900. Can i get WiFi 7 without using the EE Smart Hub Pro.
14-01-2025 10:47 PM - edited 14-01-2025 11:09 PM
@Pip-1960 It may depaend on how long you have had your service, or may mean signing up for another two years. Its a £10/month for two years option.
Best thing to do would be to give customer services a call for more details.
If you don't want the Smart Hub Pro, you are free to use your own suitable WiFi 7 router.
14-01-2025 10:49 PM - edited 14-01-2025 10:50 PM
WiFi7 is the SH Pro!
on 14-01-2025 10:53 PM
@Pip-1960 What EE Router are you using currently. Link below click view the pictures and say which one.
on 15-01-2025 09:56 AM
I asked if i an get WiFi 7 without the smart hub pro as i would like to get my own.
on 15-01-2025 09:59 AM
@Mustrum wrote:If you don't want the Smart Hub Pro, you are free to use your own suitable WiFi 7 router.
As per my previous reply.
on 15-01-2025 10:09 AM
on 15-01-2025 10:38 AM
@Pip-1960 you may find this page helpful when you get your own router.
https://ee.co.uk/help/broadband/getting-started/using-and-configuring-a-third-party-router
on 18-01-2025 12:58 PM
Yes, I've just replaced my Smart Hub Plus with a third party router and it works fine.
on 18-01-2025 01:06 PM
@BlockyMan what router did you get? Always good to hear different options.
