03-11-2024 10:45 PM
Just bought the Full Fibre 150 plan and was wondering how long I would need to wait to access the EE WiFi hotspots?
It's not letting me log into it with my EE account credentials so I'm not sure if I need to use a separate login for the hotspot or if I'm just being impatient (I'll assume the latter but its worth making sure).
04-11-2024 10:12 AM
Hi @JOAT_Official,
Welcome to the EE Community
Is your EE Broadband plan active as once its active you should be able to access the hotspots.
With you being a New EE broadband customer once you connect to a EE Wifi hotspot you would just login when prompted using the same EE ID that manages your broadband account for the app/website, so no need to create a separate login.
If your broadband is active and you are having issues connecting, you can reach out to the EE Wifi hotspot team via e-mail or phone using the details here Contact us | Find WiFi hotspots | EE WiFi
Alex
