Fourth Smart Hub Pro
Rob0313
Hi, just wanted to ask, I have WiFi 7 and I have 3 Smart Hub Pro extenders. I purchased a fourth on eBay. This connected and was showing in the app with no problems. Initially it showed no signal but after around 12 hours it was showing great signal. The light on it is aqua, which means it’s connected, but I’ve now noticed it is no longer showing up in the app, it’s disappeared. Do I just need to reconnect it or is the router not designed to have more than 3 extenders? Just wondering if anyone can let me know. Thanks
tnj
Skilled Contributor
Skilled Contributor
I have had 5 extenders connected to the Hub via ethernet. The Hub is not very good at reporting the connections and is often incorrect in stating the connected speeds and the method of connections.
Ah thats good to know. I’ve found the app to be laggy, they really need an independent Broadband app.
Thank you for your response.
