Fibre to full fibre?
csyrad
Hi, I know a few people that have had their fibre broadband to full fibre but these were changed by Openreach, so do us EE broadband payers get that option as well?  If we do does anyone know if its more expensive to go Full??
Thank You
CSyrad.
Partial Fibre to Full Fibre is not updated by OR off their own bat. They will have been instructed to do so by an ISP.
You may ask EE to upgrade to Full Fibre. It is often at the same price as partial Fibre of the same speed. If EE allow you to upgrade they will want you to move to a dearer plan if you are still within your min. term.
But can you get Full Fibre there? What does BT Wholesale Broadband Availability Checker estimate for your phone number? Post the whole table and the line above it, blanking out your phone number. If it doesn't recognise your phone number or you don't have one, use the Address Checker.
