Fibre internet and phone stopped working
idj20
Hi, my fibre internet and phone have stopped working an hour ago. Only had the service from new for a month! Location is Folkestone Harbour.
I get orange flashing light on hub and three green lights out of four on wall connector but middle one is flashing.
Mustrum
@idj20   have you tried a switch off then on again?
Or you could contact customer support by following the steps in the help pages.
Contact us about your broadband and landline
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
From your EE mobile
150
From any other phone
0330 123 1105
Calls are free from an EE number. Charges may apply if you call from another network.
Support for Deaf and hard of hearing customers
Text relay
To use the text relay service from your smartphone, PC or tablet, download the free Relay UK app.
To call us through the Relay UK app or from a textphone, dial:
18001 07953 966 150
Sign language services
If you need the support of a British Sign Language (BSL) interpreter, you can contact us through the InterpretersLive! service.
Connect to a BSL interpreter
6 REPLIES 6
Mustrum
Opening hours:
Call us
From your EE mobile
150
0330 123 1105
Text relay
18001 07953 966 150
Have done the on/off thing on both hub and wall connector, still no change. Will try the text for help thing.
Apparently there is a fault and will be sending an engineer out to investigate.
That was quick, but disappointed that its already glitching in just a month from newly installed. I thought it was bad enough with my old copper cable broadband with Talk Talk. 😅
Good job I have a reliable 4G mobile internet account with Vodafone as back up and enabled me to log in here.
Peter_W
Thanks for the update on this one @idj20.
Please keep us posted on how things go 😊
Peter
All mended. Engineer said the cable management was good but the optic fibre inside the junction box wasn't properly sealed so it was leaking light. Shouldn't be no more issues.
Now I see why those grey junction box are always located at the bottom of houses, makes it easy to access without ladders. 😅
Thanks for the prompt service, hopefully it'll be a long while before you hear from me again.
Peter_W
I'm really glad to hear that's sorted for you @idj20 😊
Have a great rest of your weekend, too!
Peter
