Fibre broadband
salmoliv
I've received an email from BT. My fibre broadband contract is expiring soon.
1- I can renew with BT, but somehow I need to upgrade to a package with options I don't need. 900Mb / £48
2- I've logged into my EE account and can get a 1.6GB fibre broadband for cheaper. £42 I think (I can't check as the website is under maintenance ...) - and I think I can add TV
3- As I have BT and EE, BT (or EE) has kindly offered to migrate my package ... but I can't choose the 1.6GB option. And the 900Mb is more expensive than staying with BT (doesn't make sense) - and I can't add TV
So, I guess my choices are:
1- stay as it is, it works well
2- cancel BT and go with EE
Anyone else had a similar dilema? Which option have you chosen?
7 REPLIES 7
A picture is worth a thousand words ... Screenshot 2026-03-25 at 23.42.41.png
salmoliv
Am I missing something obvious? Why is my post not allowed?
Option 1.
The prices you see on EE website are for new BB custs. You won't get those as your not a new cust to BT/EE. If you want to to move to EE you need to do it thro' your BT a/c.
Is "hardware" a link? Just try clicking Reply again.
Yes, a hyperlink. Aren't they allowed?
But I will be a new broadband EE customer, no?
I've never had broadband with EE before ... my contract has always been with BT.
I forgot Option 4. Virgin Media. As nowadays, new customers seem to be rewarded more than loyal ones ...
BT & EE are both part of the same group. So when you move from 1 to t'other you are counted as an existing customer.
Hyperlinks are permitted but I don't know why it's failing if a repeated Reply doesn't fix it. Maybe it's the URL under the hyperlink. What is that?
