Fibre Max 100/300
tuke8
Hi
i just want to know if router supports gfast (i mean build in gfast modem)
and does this need to be installed into master socet aswell?
i just dont have space
thx
19 REPLIES 19
Fibre Max comes with the EE Smart Router which incorporates G.Fast. Like all DSL BB it needs plugging into the master phone socket.
As well as what? What don't you have space for? What else have you plugged into the master phone socket? Can't you just use a splitter or dangly filter? Explain your problem! I'm sure it'll be surmountable.
tuke8
I'm thinking about 150mb but i have a problem with the master socket location, it's in the tiny corridor next to the main door, well my question is that does it have to be connected to master socket or it will work in another sockets as well what are in the house?
James_B
EE Community Manager
Hi @tuke8,
It's recommended that you connect your router directly to your master socket.
i understand that but it will work in upstairs socket? Maybe I lose 10mb?
@tuke8 : It is not to be recommended to use anything other than the master socket, particularly for G.Fast. It won't be just a matter of speed but more of interference & noise. Can't you run an extension cable?
James_B
Hi @tuke8,
It would depend on the quality of your internal wiring. The only way to check would be to try it.
well atm i have Plusnet 65mb and I never had problems with speeds when my router is connected upstairs socket its been a very stable connection last 5 years I understand g fast is a little bit different, but how much different if I lose 15mb just for extra distance its fine.
G.Fast is more fragile than VDSL. But suck it & see!
Mustrum
@tuke8   , so impossible to predict what you will get.you may get an idea if you enter your number in the DSL checker and post the results, obscuring your phone number.
If you are getting 65Mbps on an extension, I would have thought you would be getting 80Mbps on a filtered master socket or test socket. But as has already been said, G-Fast is even more demanding on ancient telephone wiring.
A better solution would be to get the master socket moved to where you need it, however getting Openreach to do so is likely to cost circa £150.
