18-12-2023 09:30 PM
How can I go from 900 mbps to 125 by signing with EE on the same tariff? And I was assured on several occasions the speeds will be the exact same because its powered by BT ? I've been with EE for 2 days and already having problems . I was with BT for 10 years and every problem I came across which was rare was either compensated or solved over a live chat yet EE doesn't even have a live chat it's not the best start , I'm hoping this moan some how gets me the help I need
19-12-2023 12:23 PM
Hi @Gingerja87,
Thank you for posting. I'm sorry if you've seen a drop in speed since you moved to EE. How are you testing your speeds are you using a wired or wireless connection? What device are you using?
If you're seeing a drop in speed on wireless adjusting the location of the Hub and Smart Disk can help. As well as changing the wireless channel.
Thanks,
Paddy
