Faulty Hybrid device wont power up
SeanyW
Just upgraded from BT to EE but the Hybrid Connect device will not power up and has no lights
Maybe power pack or device
called EE but only option seems to be raise a fault whixh is tested by a bot and comes back Ok
How do I speak  to a human to swap out faulty unit?
@SeanyW : You need to raise this with CS. Text GUIDE to 66033 & they'll call you back.
Tried that but when I request tech support it sends me a text message bot to check my line
No options to speak to a human or report/replace the device which was dead on arrival
Matt_124
After giving it time to run the line check it usually then gives the option to reply with GUIDE once it has concluded.
