FLASHING YELLOW
myles51
Hi, for past 3-4 days router flashing yellow for long periods of time get it back for few hours but goes straight back to flashing yellow. Working from home used all mobile data not happy how can this be fixed. Thankyou
bobpullen
Here's probably a good place to start. I think following the links from there will take you down the route of testing your line/raising a broadband fault.
A flashing yellow LED suggests that the router has lost the connection with the local cabinet, so you may well be looking at a physical line fault. if so, it will require Wholesale/Openreach intervention to fix.
Mustrum
@myles51   you can find more details on how to get help from the following page:
https://ee.co.uk/contact-ee/technical-support/broadband-landline
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
We’re open every day:
Call from your EE mobile
150
See call costs
Call from a landline or another provider
0330 123 1105
@bobpullen : Here's can only check mobile network status. For a manual check on BB network it's texting 66033 that @Mustrum suggests.
If it is a neighbourhood issue, you could consult BT Service Status to see if any faults are being attended to in your local area.
