FFTP 900 - Latency Issues
Sean_W1
Hi all,
Over the past week I have been having really bad latency issues with my service across multiple devices. The service up until the past week has been great with no issues what so ever but has deteriorated to the point where I'm unable to do any gaming what so ever.The blips in latency happen simultaneously across multiple devices.
Ive been in touch with EE and an engineer came out and has came to the same assumption as myself into the fact it is down to the router so this is getting replaced next week although I've got a sneaky suspicion that it won't solve the problem.
Things I've tried so far :
  • Remove wireless interference - 1 connection at a time.
  • Turn off WiFi 6
  • Change the channels on the router
  • Power cycled both the router and ONT
  • Factory reset the router
  • Run 2.4 ghz connection instead of 5ghz
None of the above has made any difference in terms of connection and the only stable way of getting decent latency is with ethernet to which there are no problems what so ever but this is unfeasible for my main computer which is situated upstairs.
If anyone has any other potential improvements/solutions to my situation I'd appreciate it!
0 REPLIES 0
