Wi Fi 18gb
jenbird
Hi, appreciate any advise given.
My Bt internet was working fine and EE took over my broadband and phone (accidentally) they took the wrong line as they were suppose to take the garden room.
Since then our speeds have dropped to 18GB. Wi-fi doesn’t reach all areas of the home even with 3 wi-fi (ee) extenders.
Sky keeps turning off, and we are only able to watch 1 TV upstairs otherwise it all cuts out.
hub has been moved to another room (main living room) sky is hardwired
any advise?
7 REPLIES 7
@jenbird : Which EE BB plan are you on including its speed? What EE router do you have?
You can't mean 18 GB. I shall assume you mean 18 Mbps speed.
Sorry 18Mbps. Im on the essentials Fibre 36
jenbird
Hello,
thanks for the suggestions i dont know how to log in to my smart hub when on the ee app there is no link for advanced settings
the broadband checker says sorry unavailable at this time
my current download speed is 13.7
Login to your EE Smart Hub/Router at http://192.168.1.254 with the admin password on the bottom of the slider label on the back of the router.
Mustrum
@jenbird  You may also use the info on the Help pages to have your line tested and to contact the Broadband Care Team.
https://ee.co.uk/help/contact-ee/technical-support/broadband-landline
Contact us about your broadband and landline
Text EE for a call back
If you need help with your broadband, text HELP to 66033
If you need help with your landline, text PHONE to 66033
Charges may apply at your standard rate.
  1. We’ll run tests on your connection to find out what’s going on.
  2. If you need an engineer, we’ll text you in 15 minutes to book a slot.
  3. If you don’t need an engineer, we’ll call you within 30 minutes to help solve your issue.
Opening hours:
Monday to Friday, 8am to 9pm
Saturday and Sunday, 8am to 8pm
Call us
From your EE mobile
150
From any other phone
0330 123 1105
Calls are free from an EE number. Charges may apply if you call from another network.
Text relay and sign language services
To make a text relay call using the Relay UK service, dial 18001 in front of the following number:
07953 966 150
Contact us through a sign language interpreter
jenbird
Thank you I have called but its over a 40 minute wait.
this is what i have found hopefully you find it useful
