FF Installation Outside Work
smc14
We had full fibre installed today and I didn't see the outside until after the workmen had left.
My question is, should it has been left open like that?
Mustrum
@smc14   What was it like before the install?
You may want to try a complaint via the following lik https://www.openreach.com/help-and-support#accordion-64bd71f8f6-item-b9a124790d
Mustrum
smc14
The grey bit at bottom wasn't there. where hole is with the thick wire was covered with a grey covering.
