18-08-2026 10:52 PM
Hi i m trying to connect my tv to wi fi but it comes as “ei fi connection error “
18-08-2026 11:04 PM - edited 18-08-2026 11:05 PM
@Robert2507 : Sometimes older or weaker devices may not be compatible with the default WiFi settings of EE Smart Hubs. Try setting up Compatible WiFi on the router under Advanced > Wireless Settings > Config > Compatible WiFi (it defaults to 2.4 GHz only & WPA2) & connect your problematic 2.4 GHz devices to that.
