Ee hub disconnects to yellow light 4 times a day
Shahid6
Hello, about 4 times a day my ee wifi hub disconnects and disrupts everything im doing online. How do i stop this from happening because its becoming very infuriating
Only 4 times a day? Many users are reporting theirs are rebooting every 2 hours. Read the sticky on it. So yours must be something else.
Ian06
@Shahid6 have a look at this thread Smarthub-frequent-reboots .  There is a "known" problem with some of the EE routers causing regular reboots/disconnections from the internet in some certain situations.
Call EE BB customer services and if it is the same problem talk to them about getting a different router to solve the problem.  (see discussion about replacing the EE Router near the end of the above thread.)
Is it the BB as a whole dropping or just the WiFi connections? Do Ethernet connected devices stay working?
