EE hub
Geordier1
Devices will not stay connected to hub ring doorbell,Halo Central heating,even the mini box for bedroom disconnects.Tried rebooting several times ?
Community Hero
Community Hero
@Geordier1 What EE Router are you using for the connection, you may just have to setup the compatible network for those devices!
https://ee.co.uk/help/broadband/manage-use/how-to-set-up-compatible-wifi?
Community Hero
Community Hero
Smart hub 7 plus
@Geordier1 Still the same answer, try the compatible from the link above!
