on 27-10-2023 01:00 PM
Hi, We've just received a EE 5G smart hub and EE smart wifi disc. I've set the smart hub up with ease, however the wifi disc just has a solid red light. I've tried connecting via ethernet and WPS and have also tried the factory reset but to no avail. Any ideas please?!
on 27-10-2023 01:15 PM
You need to have an EE Smart Router, a fixed BB router, for the EE Smart WiFi Disc to function.
on 27-10-2023 01:17 PM
The 5G smart hub is a smart router?
27-10-2023 01:20 PM - edited 27-10-2023 01:25 PM
But not with Capital letters. It's the title of a particular router. Also it's called a "Hub" not a "Router".
on 27-10-2023 01:45 PM
Apologies, I'm not sure I understand your previous message. We have a 5G smart hub for our broadband as we're remote so it runs on a nanochip. I'm confused why the smart WiFi disc won't connect - are you saying they aren't compatible?
on 27-10-2023 02:05 PM
That's what I'm saying! The EE Smart WiFi Disc is only compatible with a particular model of router, the EE Smart Router. See EE Smart WiFi Disc :
NOTE - You need to have an EE Smart Router for this product to function.
on 13-05-2025 10:09 AM
Exactly the same issue driving me crazy running around trying to connect cameras n printer and doorbell
on 13-05-2025 12:09 PM
on 13-05-2025 12:11 PM
on 13-05-2025 12:18 PM
@kskillin The thread you've jumped on here is around 5G Hubs, which are separate to how our fixed broadband hubs work.
Which model is it you have?
Feel free to pop up a pic if you're not sure 😊
Peter
