EE hub
Barney29
Had a power cut today and EE hub has not given great service since
In what way has it not given great service? Low speeds or discons? It could be that the auto DLM has reduced your speeds when sensing the lack of or spasmodic response during the power cut.
Mustrum
Hi @Barney29   what do you mean?
Has the power remained constant since the cut?
How is your phone line? Any noise when you dial 17070 option 2?
Are you connected via ethernet or Wi-Fi?
