EE WiFi 6 extender
Daveyboy81071
Hi I have EE HUB 6 with the WiFi 6 extender the ethernet port on on back of the extender isn't working does it need to be switched on
Maestro
Maestro
@Daveyboy81071 No switch off/on for it at all, connects direct to your device and will allow wireless wifi connection if that is how you are using it, take it that it is paired to the Hub ok and has the Aqua indication on it! Help is below for all the units!
https://ee.co.uk/help/broadband/getting-started/setting-up-smart-wifi
https://ee.co.uk/help/broadband/getting-started/setting-up-wifi-extender
https://ee.co.uk/help/broadband/fix-problem/fix-problems-with-smart-wifi
Maestro
Maestro
